Rear Wheel Not Rotating?
Hi,
I just got a call from a local shop that is doing my gears and they asked if I know why the rear wheels would not roate with the e-brake off. I noticed this awhile ago while doing other work on the car, but it seems that when the car starts the rear calipers release the rotors completely.
Is this normal? I have released the e-brake in my driveway and the car can be pushed, but should it move alot easier than they are saying? The guy I talked too said he could not roate the wheel at all. they were going to disconnect the drive shaft and see if it moves freely. I think it is the calipers acting up, as when I went to change the pads last year, i had a hell of a time compressing the calipers in. I had to release all pressure to the caliper at the banjo bolt and remove the bleeder for me to be able to compress the caliper.
Sean
Sean
When you compressed the rear calipers, did you just compress them or did you turn them in?
AFAIK The rear calipers on our cars need to be turned to compress them, not just pressed in. That may be the cause of your problems.
sorry, they were turned in. I used the proper tool to screw the caliper in. It would connect to the indents on the caliper but the caliper would not screw in at all until the internal pressure was relieved.
They called you?
Damn. That would shake my confidence in their abilities. It shouldn't take more than 5 minutes to diagnose if they've already got the car a lift.
Is the car in gear?
Remove the calipers, does the problem go away?
Unbolt the driveshaft. does the problem go away?
If not, then it's something in the rear end, and well, they're claiming to be capable of tearing into that so.....
Is the car in gear?
They called you?
Is the car in gear?
Is the car in gear?
The question they asked was have I been experiencing problems in the past. They called me asking if I wanted them to look into it for me further. I would say that is a good shop, asking the customer first before doing more than they should, since time is money! I talked to them after and they said everything is fine. They are a local shop that does a lot of Mustang stuff, but I bet you i am the first S197 they have done a rear gear swap.
I could see the shop calling the customer to advise of the issue and if you wanted to spend the additional money to investigate.. but all of a sudden they are saying everything is fine? I would get the details.
Galactic
04-29-2019 02:56 PM
Luke9222
10-22-2015 11:55 PM
M3hunter
09-05-2015 03:42 PM
