05-09 mustang Headlight switch with daytime running light?
Ok ladies and gentleman it's night here and I installed it seems to work fine everything except the bulb inside the unit which I am getting replaced. I put on the A setting and it works just like the regular lights and you can pull out for fog lights. How can I make the Auto feature work?
I didint think that mustangs had the auto feature.. in a roush mustang how do you control what foglights you want? I know you can have them all on at once, only the fascia lamps or the grille at one time. I was thinking maybe thats what its for
The Roush foglight switch is separate from the headlight switch. From the factory, it's a rocker type switch in the lower dash piece below the headlight switch.
I have a 2006 Mustang GT it has daytime running lights but no way to cut them off I've been told the car must have come from Canada I don't know I just want to know do they make a switch that you can replace your stock one and be able to turn them off
inyadreems
08-21-2015 09:10 AM
