Questions on Guages. - Page 3 - MustangForums.com
Old 09-04-2011, 04:09 PM   #21
2007CalSpec
2007CalSpec's Avatar
Quote:
Originally Posted by Blacksmoke View Post
Aeroforce makes a wide band AF dont they?
Not really but you can buy the wideband sensor kit and make it a wideband.
http://aeroforcetech.com/products_sensors.html
2007CalSpec is offline   Reply With Quote
Old 09-06-2011, 10:15 AM   #22
Hamhole
The purpose of a wideband A/F gauge is to give you the exact air/fuel ratio in either Stoichiometric units (14.7 being optimal) or Lambda units (1.0 being optimal).
A narrowband can only tell you "RICH" or "STOICH" or "LEAN". Even with a wideband sensor, the gauge would read either "RICH" or "STOICH" or "LEAN" and blink like a Christmas tree light because it won't have a digital read-out telling you what your air/fuel ratio actually is.
Hamhole is offline   Reply With Quote
Old 12-15-2011, 08:21 AM   #23
Vegas GT
I need help. I bought the triple dash pod for my '06 GT with Autometer Volt meter, oil pressure and water temp 'cause I heard they'd be easy. The volt meter works fine but the oil and water only go all the way left or right because their getting signal from the computer which goes to the idiot light so it only reads OK or bad. Any advice? Is there an adapter for the water temp?
Vegas GT is offline   Reply With Quote
Old 12-15-2011, 12:04 PM   #24
forensicsteve
no cutting of the dash is required
Nothing wrong with a cut here and there...the occasional slice...adding a gaping hole or two or three...blocking up other holes...gives the car character.
Go the total sleeper route as I did (pic)
forensicsteve is offline   Reply With Quote
Intake manifold replacement Dokilar 4.6L (1996-2004 Modular) Mustang 15 10-16-2015 08:13 PM
Win $1500 Worth of RTR Parts - AmericanMuscle AMAlexLazarus AmericanMuscle.com 3 10-02-2015 08:06 AM
October Sale - AmericanMuscle AMAlexLazarus AmericanMuscle.com 0 10-01-2015 10:29 AM
Hot Lap: 2015 Roush RS3 Test + Build a Supercharger! - AmericanMuscle.com AMAlexLazarus AmericanMuscle.com 0 10-01-2015 09:21 AM
Hello, new user with an older Mustang and a question treesloth New Member Area 4 09-28-2015 07:03 AM
2008, 2011, autometer, built, cobalt, cup, fitting, gauge, gauges, gt500, mustang, nexus, pod, sale, shelby, wideband
Featured Sponsors
