Can I put front calipers and rotors on the rear as well?
The FR500C Ford factory built race car uses the OEM equipped rotors and calipers back there...
So that sure answers the question of why would you need to change anything at the back guys.
You all need to spend your money wisely, on things that count...
That is good to know. I am about to rotate my tires again, I will have a peek at the hardware mounting equipment for the calipers and see if they are indeed exactly the same dims. I like the idea of having two piston calipers (a total of four back there).
I will also look at how the e brake works there too.
at all and could be quite dangerous in a emergency
stopping situation.
My rear OEM pads are shot and the rotors are worn
as indicated by the 'ridge' on the outside egde but the
front OEM pads dont even look worn at all and the rotors
dont have the 'ridge' yet at the edge.
Seems to me, my rears are taking all the stopping power.
ps I dont have ABS on this stang...
inyadreems
08-21-2015 09:10 AM
Daleford
08-10-2015 08:30 PM
