Buying PA Performance Alternator
Hi Everyone,
So 6months after fixing the alternator, Im getting the "Check System Charging" again, So i just decided to buy the Pa Performance Alternator 6G Alternator 130 AMP (large case), could not find anything good and cheaper.
The page says:
"** We require that you upgrade the main power wire due to higher output than stock on vehicles where this is an upgrade**"
Does this is a requirement for my 2007 V8 GT and what does that means, how do i upgrade the main power wire if needed ?
Thanks!
The page says:
Thanks!
Stock should be 8 gauge.
BTW, you should look into doing the Big 3 Upgrade. It def helps alot.
http://http://www.the12volt.com/installbay/forum_posts.asp~TID~73496~PN~1
09-08-2015 11:50 AM
M3hunter
09-05-2015 03:42 PM
07, alternator, alternators, charging, chattanoogatn, check, gt, mustang, original, pa, paperformancecom, performance, power, sold, stock, system, wire
