Considering 4:10's
For my next mod i'm considering a set of 4:10's ..I would like to hear from the 05/06 owners out there who have had em installed..Did it pick the car up that much?..Any regrets in having them? How bad did it kill your gas milage?
RE: Considering 4:10's
I'll let you know after tomorrow. Supposed to pick up my car Friday evening.
I know my car is not a 3 valve but i went from the stock 3.27s to 4.10s and my mileage did not go down at all. It is not as much of a change from your 3.55s as it was for me.
At high speed on the highway, I think you would lose a little bit of efficiency because the RPs will be higher but as long as you keep your foot out of it it should be fine. |
ORIGINAL: MikeHawke I know my car is not a 3 valve but i went from the stock 3.27s to 4.10s and my mileage did not go down at all. It is not as much of a change from your 3.55s as it was for me. At high speed on the highway, I think you would lose a little bit of efficiency because the RPs will be higher but as long as you keep your foot out of it it should be fine. |
[sm=exactly.gif]
i put on the 3.73's and it is still hard to keep my foot out of it...i could only imagine if i would have gone with the 4.10's. the only thing you are gonna do is lose top speed and have higher rpm's at those higher speeds. it's a good trade off though. |
Dear Mac10chap,
I just want to compliment you on the look of your car... It is "SMOKIN'"... I also had the 3.73s installed and later a supercharger... Best all around gear selection... Strong acceleration, good highway performance and not too much gear for the addition of an S/C.. Best of Luck, Dave |
Running 4:10 and recommend them, even with a blower. No noticible loss of MPG.
if traction becomes a problem, just go with more rubber
already got 295's out back (on a 10" rim) |
what is the car supposed to come with? someone said 3.55's
however i when putting on my slp's i notice the rear differential box read "Ford 3.31" |
3.55's for the manuals... Auto's came with something lower...
| All times are GMT -5. The time now is 05:23 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
