I just installed longtubes and cams but need some cats back on the car. Too loud and too smelly. I was thinking of having the stock cats welded back in if they will fit. Brenspeed said it should be a problem performance wise. Anyone ever done this? I havent looked under the car yet to see if they will fit.
I had the same problems and had to install cats on my Pypes O/R X. The pipes on the stock cats are slightly bent and I wasn't going to be able to install them easily. I ordered the pypes cat kit from AM and sold the stock H-pipe. Its a simple install if you have a cutoff saw. They did end up cooking my feet though (extra fuel from cams maybe??) so I added some extra heat shielding from jegs.
