Whine after UDP's
I had UDP's installed last week and since then I have an alternator whine. Is this normal? I was told it was because the alternator is now having to work harder so its going to whine.
Less than one year ago I had a PA Performance Alternator (130) installed and a new battery, so I doubt either of those could be an issue. Thoughts?? |
did you install a supercharger?
Did you use a new serpentine belt or the same one with the other pulleys?
Originally Posted by 99GTvert
(Post 7717286)
When I had UDP's installed on my car, I still had the original belt on there. After a bit it kind of sounded like a whine was coming from the front of the car IIRC.
I replaced the belt after talking to the installer...it stopped the noise. I think the reasoning was something about the grooves being either slightly different...or something, I don't remember exactly. I think it was the same size belt, though. Now, that is for an older bodystyle GT. I don't think the 3V's would be any different but hopefully someone else chimes in. |
I got a whining after installing my m90 and still cant figure it out =/.... lol
All jokes aside, are you 100% sure the belt is tracking properly? And just because you bought a NEW part, doesnt always mean its perfect. |
I have the Steeda UDP on my car and it makes Zero noises..sounds just like it did day i bought it..i would say something isnt right if its making a noise. something could be rubbing..not tight enough. What brand UDP did you install..did it come with a larger water pump pulley so you can just keep factory belt?
I checked the belt and everything is tracking correctly...
I did buy these used from a reputable member on another forum and are the Summit Racing "brand" and the water pump pulley was larger. I was listening to the whine this morning and did notice it does NOT increase and decrease with the rpm's like a regular alternator whine would do.... |
Anyone have anything to add that may help me here? The noises from my car are starting to aggrivate me, especially the ones I know shouldnt be there, like the alternator whining and the gear whine I have.
| All times are GMT -5. The time now is 06:42 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
