Sponsored by:
Sponsored by:
Gear whine! Will it go away?!
Old 10-31-2011, 05:46 PM
BlackBeauty4.6
BlackBeauty4.6's Avatar
Default Gear whine! Will it go away?!
Just installed my 4.10s .. Now everything felt fine and double checked everything.. Now there's no noise at all until deceleration and is the loudest from 50-35.. Now when I push in the clutch it goes away the gears are ford racing I checked the serial number it ends with an A will they whine go away?? After some miles are put on or am I screwed? If it gets louder I'm gonna check the slack side to make sure the wears good I just hope the noise goes away
BlackBeauty4.6 is offline
Old 10-31-2011, 06:11 PM
alkemist
alkemist's Avatar
Gear whine will not go away. Once the pattern sets in, that's pretty much it and that starts once you drive the car. Make sure you go through the cool down periods and slowly wear in the gear though.
alkemist is offline
Old 10-31-2011, 06:25 PM
mtflyboy25
mtflyboy25's Avatar
Nope. It is there.... FORRRREEEEEVVVVEEEEERRRRRRRRRRRRRR!!!!!!!!!
mtflyboy25 is offline
Old 10-31-2011, 06:46 PM
BlackBeauty4.6
Damn it!! I'm gonna try and set the slack side better I can't remember are the shims behind the bearings? Or where?
Old 10-31-2011, 07:27 PM
CutterWolf
CutterWolf's Avatar
If you have gear whine the install is wrong sorry bro
CutterWolf is offline
Old 10-31-2011, 07:41 PM
SoCalGT08
SoCalGT08's Avatar
What was done wrong?
I have a similar prob....checked and rechecked backlash, said it was OK....changed gear oil after break in....still hava lil noise
Mine is not really a whine, but def a noise on the DE Cel side at around 40mph
SoCalGT08 is offline
Old 10-31-2011, 08:24 PM
Ricardo
Ricardo's Avatar
No whine here but I got mine done at a shop that works on Mustangs only. And the guy that did my install does the gears for the shop.
Ricardo is offline
Old 10-31-2011, 10:55 PM
BlackBeauty4.6
See that's what I don't get... Cause everything was put back right the back lash is set good.. The pinion is sitting right in the middle there's not to much play it just doesn't seem like it was done wrong..
Old 10-31-2011, 11:19 PM
SoCalGT08
SoCalGT08's Avatar
Same here.......
Mine was done by a Mustang Mech who has done a hundred of them.....wierd and a bit annoying.....
Old 11-01-2011, 12:51 AM
gabb
gabb's Avatar
Is the car lowered? That might have an effect on the pinion angle.
I'm on my second set of gears, both were ford racing 3.73, this set is alot quieter than the first. Not silent but not noticeable unless you listen for it. I was told that a 1 piece DS might help also. Good luck.
gabb is offline
Quick Reply: Gear whine! Will it go away?!
