What Do You Think of These Wheels?
Looking at getting black wheels for the spring. Found these and think they look pretty cool. http://www.americanmuscle.com/blacks...8x10-0510.html What is the tire pressure sensor that is mentioned?
It would depend on your color of mustang. I like it in the blue but not the red.
In newer mustangs, I am not sure when they started, they have pressure sensors that will tell you when the air in your tires are low. It will read on your dashboard. But you have to have that option installed to work.
The tire pressure sensor mentioned reads the air pressure in your tire and will alert you when the pressure reaches below a certain point. You will have a pretty little orange ! on your dash.
For a 2010 mustang you will need valve stem sensors. If you order them through AM call them and let them know what year you have and have them check availability on everything. Also tell them you are on this forum and you can receive a discount. But you need a code. Talk to this guy for the code.
Is it worth getting this then: http://www.americanmuscle.com/blacks...1011-stag.html staggered setup with Nitto tires?
jwog666
12-27-2021 08:09 PM
mungodrums
09-28-2015 10:54 PM
