2006 Mustang GT rear end clicking noise
wow, ok finally got to where I can post a question. I have a 2006 Mustang GT with 46,000 miles on it. I have a clicking noise coming from the rear that is starting to get louder. It is only noticeable when I am slowing down, off the throttle, does not matter if I am in gear or not. I've check the diff and changed the oil. Same with the transmission. Any ideas on what it can be?
Ric
Ric
if it happens just before coming to a complete stop, then its probably your stock upper control arm. I believe it uses a 14mm bolt in a 16mm hole, or some measurement like that. as you slow down, the bolt shifts a little and causes a knock.
NorthAmericanTuning
03-18-2016 11:21 AM
91StangOwner
08-20-2015 11:34 PM
92 5.0stang
08-13-2015 06:46 AM
