Just ordered my CAI & tune
So, after browsing through American Muscles cyber monday sales, I came across the C&L CAI and sct tune, which was on sale. I figured I should get the deal while I can, especially since the C&L's are usually a little more pricey. That, plus the MF discount code.
Anyway, I ordered the 87, 89, and 91 tunes. Is there anything specific I should know or consider about installation and usage? (apart from the silly things, i.e. correct gas and what not)
Once you receive the package and install it, I would recommend using the technique that NUKE suggests... Load the lowest octane tune 1st and drive it around and then install the next higher tune, driving around on it too. If you still aren't satisfied, then load that last, highest octane tune and try that out... There will be subtle differences in each tune that would likely be even less obvious if you load the highest octane tune right off the bat and then work down to a lower octane tune. Then you can decide which is best for your driving habits.
Also, start now with your next fill up and start filling your tank with the highest octane gas that your tunes were ordered for, in your case, 91, if you haven't already been running it.
Good luck and I hope you enjoy the kick. Definitely worth the cost of admission.
Don
Don
Not to hijack the post, but thanks for that info. I ordered the same thing (C&L CAI with SCT Tune), but I just pressed 93 for all tunes. I sure I should be able to call BAMA to email me different tunes so I can start lower and go higher if desire.
As I always recommend, have the tank full with the octane matching your highest tune, then take the car for a spirited drive FIRST and pay attention to how she spins up and everything. Install the CAI and then load the LOWEST octane tune first, followed by a repeat of that first drive. Load the next higher tune and repeat the drive and so forth. You may be surprised to find that you prefer a lower octane tune for use as your DD tune.
That's why I always recommend trying each tune by comparing stock first and then thru the ascending octanes.
