Grill with lights (OEM) install question
Since you don't have one on there now, I am presuming you have a V6 Pony... You will need to get a V6 specific GT appearance grill, otherwise you will need a new front bumper to make the OEM GT grill fit on a V6.
As far as wiring, you may need a new headlight switch if your current one doesn't pull out towards the driver to activate the fogs... The only way to determine if you have the wiring to power the fogs would be to open the hood and remove the radiator cover and peer down behind the grill.
Don
Don
You will need the wiring & switch as well as the grille & fog lights. As BigDinTexas pointed out, you will want to source the aftermarket grille that is styled like the GT but fits the V6 front grille opening. We have a kit that includes the grille, fogs, wiring, & switch that gets you everything you need for the install. The chrome grille pony is the same between GT & V6, so you can re-use your original.
Diode Dynamics
28
05-26-2022 12:02 PM
inyadreems
08-21-2015 09:10 AM
