Sponsored by:
Sponsored by:
17" winter tires on 2011 GT?
Old 12-14-2011, 09:34 AM
medgar227
medgar227's Avatar
Default 17" winter tires on 2011 GT?
Hi all,
I was reading up on the threads referring to winter tires, and didn't find what I needed. Anyway, I am looking to purchase a 2011 GT. My questions is, can I get 17" rims and tires for my winter setup? I prefer a taller tire (matching OEM diameter) for a winter setup which seem to absorb the pot holes better in michigan. Plus that size is much cheaper.
I currently have a 2003 G35 sedan and use a 16" setup for winter, which does not an issue clearing the brakes even though the OEM size is 17.
medgar227 is offline
Old 12-14-2011, 11:13 AM
medgar227
medgar227's Avatar
So I guess I just want to know, will a 17 inch rim fit on a 2011 GT?
Old 12-14-2011, 11:20 AM
1slow67
ROTM Moderator
1slow67's Avatar
They should, I know some won't if you have the brembo brake setup though.
1slow67 is offline
Old 12-14-2011, 11:25 AM
medgar227
medgar227's Avatar
Ok, I just wanted to know if someone has done it before. When I went to tirerack the smallest size they recommend for standard or brembo is 18.
Old 12-14-2011, 11:52 AM
Nuke
Nuke's Avatar
You can still go with an 18" snow tire. It's the tire OD you want to maintain as close to the stock tire OD, regardless if the wheel is 17" or 18". Also, for snow tires, the skinnier the better.
Nuke is offline
Old 12-14-2011, 12:59 PM
medgar227
medgar227's Avatar
Right, I know they make 18" snow tires but I would like a higher tire wall by going with 17" and maintaining the same diameter. Tire rack has 215/60/17 for $110, and they have almost the same diameter as the stock 235/50/18's.
I could probably save at least $400 by going with 17" rim and tires.
Old 12-14-2011, 04:40 PM
ym42
ym42's Avatar
When I was looking into it, I also discovered that stock rims are too wide for tires <225...
ym42 is offline
Old 12-15-2011, 01:33 AM
scottybaccus
scottybaccus's Avatar
Unless it has the Brembo brakes, yo could pick up a set of 17" rims from the base V6. Then you could put whatever tire on it you want.
With the Brembo brakes, you must use 18" or larger.
scottybaccus is offline
Old 12-15-2011, 07:41 AM
medgar227
medgar227's Avatar
Thank you! This is what I wanted to confirm.
Old 12-15-2011, 07:42 AM
medgar227
medgar227's Avatar
Good to know, but I would probably get dedicated rims for the winter.
jwog666
12-27-2021 08:09 PM
CS2007
06-25-2019 09:45 PM
KingRando
10-02-2015 08:06 AM
BeatnikFink
10-01-2015 08:00 PM
marc954
09-29-2015 11:18 AM
Quick Reply: 17" winter tires on 2011 GT?
