Whats the best clutch! Its clutch time...
I'm thinking about going with this setup, anyone's thoughts?
http://www.americanmuscle.com/spec-stage3plus-05gt-clutch.html
http://www.americanmuscle.com/spec-aluminum-flywheel-2005-gt.html
Just looking for alternatives and input to base my decision on. The Exedy Mach 600 which is what I would need is $600 alone and with the alum flywheel that's close to $1,000.
The same setup with the 3+ is $800.
I could of sworn I've heard people say the 3 is ok, but the 3+ sucks.
Cant you keep the stock flywheel with the RST? So you wouldn't need to spend $300 on a flywheel.
You should do it right the first time, and get the RST so it'll handle whatever you can throw at it!
Seems the best bang for the buck IMO for up to 700 RWHP!
Always go for overkill when upgrading transmission components. The labor involved in dropping the transmission is difficult/expensive enough that you don't want to do it any more often than absolutely necessary. Get the highest HP/TQ rated clutch that you can comfortably afford as long as it matches your streetability requirements.
