New M90 owner
#31
Off at all times. What does the TC do when you lose traction? It cuts fuel. What happens when you go lean in FI motor? You go boom. Turn that **** off everytime you drive and learn to control wheel spin with your right foot.
I think 255 is about as wide a tire you can put on a stock rim. You may need to consider some new rims. I am running 285s and cant imagine running the stockers./.......slippery man.
#33
Oh and I drove my s/c stang for 3 months before I started turning off TCS... I just never thought about that. Glad it's all okay, maybe its a lot more harmful if you're running like 10 lbs, 500hp, etc.
#34
I definately have not seen a post where someone went boom from driving with the TC on. LOL
#35
i have alwasy been told to keep it off on these cars when you have a supercharger, this is because to take power away from the cars tires it will lean out your tune apply the brakes and whatever other voodoo magic ford put in there , so you dont want to lean out while running boost, i think i have kenne bell article on it somewhere
#36
Driving around with a ford stock tune in a stock FI Ford vehicle your probably safe with the TC on. If your car is loaded up with after market parts and an after market tune turn that **** off. Running WOT whether at the track or on the street you want the TC off. Its common knowledge with FI at WOT you dont ever want to go lean. Why risk it? For me, I turn it off every time I drive just like I put on my seat belt every time I drive my car.
#37
I almost always have mine in Sport Mode and always turn it off on the dyno or at the track. But it doesn't work the way you are stating it does.
#38
Factory FI tunes are notoriously rich ie conservative. After market tunes tend to push the limits, lean it out and make more power. Which is fine except when you get into a "lean" situation and starve the motor of fuel. As far as TC is concerned, it works the same with whichever tune is loaded in. Your N/A setup does not have the same risks as a FI setup. If you were FI the last thing you want to encourage is a lean condition.
#40
Check out fnsweet.com That is a Roush specific site where I have seen used m90s come up for sale. You can also check JDM. They are a Roush dealer and I have seen them put used ones up for sale as well. Buying a new one for a deal. Hard to find. Maybe try Gary Yeoman Ford.
