Sponsored by:
Sponsored by:
2007 Mustang Ran Into A Issue Installing TSW Wheels. Need advice? Bore wheels?
Old 02-29-2012, 08:31 AM
BayInstinctz
BayInstinctz's Avatar
Default 2007 Mustang Ran Into A Issue Installing TSW Wheels. Need advice? Bore wheels?
So I recently bought TSW Snetterton wheels, the front being 20x8.5 and the back being 20x10. I took it to a tire shop to get them installed, but they said that only the back wheels fit and that the front wheels didn't. The center bore diameter on the front wheel was too big for the wheel. The guy said to bore the wheels out to at least a 3in diameter=76.2mm, and about 1/2 depth I believe just to be sure. I thought all mustangs had a 70.5mm center bore diameter? And I saw on a website that the wheels have a 73.1mm center bore diameter. Should I just take the wheels to a shop to bore them out or buy spacers? I need some suggestions.
http://api.viglink.com/api/click?for...13305258434471
Anywhere in the Bay Area that bores wheels?
BayInstinctz is offline
Old 02-29-2012, 10:09 AM
SpartaPerformance
SpartaPerformance's Avatar
If these wheels are made/sold for Mustang they should fit. I'd contact the company and ask them what the deal is. It may be the fronts were boxed wrong.
SpartaPerformance is offline
Old 02-29-2012, 12:05 PM
Woodro
Woodro's Avatar
Yeah I agree with what Sparta says, but u only have 3 options as far as I can see, let seller figure it out, bore them or use a spacer of some sort
Woodro is offline
Old 02-29-2012, 06:06 PM
MELLOWYELLOW06
MELLOWYELLOW06's Avatar
I believe the hub on our cars are 76.1 so the CB on the wheels need to be 76.2.
MELLOWYELLOW06 is offline
Old 02-29-2012, 06:24 PM
CutterWolf
CutterWolf's Avatar
Yep, check with who sold you the wheels and make sure they are the correct ones for the front before you do anything else
CutterWolf is offline
Old 02-29-2012, 11:56 PM
BWfVA
BWfVA's Avatar
Yeah I would let maker handle it so you dont void any warrentys or do anything they can say is your fault.
BWfVA is offline
Old 03-01-2012, 10:09 AM
BayInstinctz
I bought them off someone on eBay, so that's not going to happen. Weird because I thought the hub size on Mustangs were 70.5mm. And the hub size on the rims are 73mm. Thing is, the rim only has so much depth which is why it doesn't stay on, so I need to have it bored to a 5/8" depth I'd say.
Old 03-01-2012, 10:12 AM
BayInstinctz
Old 03-01-2012, 10:17 AM
Tex-stang
Tex-stang's Avatar
If the seller on ebay said they would fit then file a complaint. They hate it when you do that.
Tex-stang is offline
Old 03-01-2012, 10:22 AM
BayInstinctz
No, they didn't say if it fit. I mean it's an easy fix. I got four 20" TSW Snetterton wheels with tires for $650. Not bad.
djbigskrilla
09-20-2022 01:04 AM
mstahoo
SVT Forums
08-19-2021 09:15 PM
'stangdude
08-12-2015 01:27 PM
daytooday
08-11-2015 09:22 AM
Gregz
08-11-2015 03:42 AM
Quick Reply: 2007 Mustang Ran Into A Issue Installing TSW Wheels. Need advice? Bore wheels?
