Sponsored by:
Sponsored by:
Fog light wiring
Old 03-23-2012, 01:49 PM
rocket fuel
rocket fuel's Avatar
Smile Fog light wiring
Hello,
I have a 05 V6 and am currently in the progress of wiring my fog lights, but I have come a snagging point. What is the best way to connect the wiring form the cab to the engine compartment, i have both sides done but cant think of a good way to connect them.
Any help is greatly appreaciated
rocket fuel is offline
Old 03-23-2012, 02:31 PM
2007StangV6
2007StangV6's Avatar
Are you talking about to get the wire running to your fog light switch?
I believe if you pull the front driver tire off and pull the wheel well cover off, (not sure what to call that big piece of black plastic), there should be a hole that's plugged up. Pop out the plug run your wire and then plug the hole back up. Simple and easy to do!
2007StangV6 is offline
Old 03-23-2012, 02:40 PM
rocket fuel
Ok, Thanks, i was looking at that but I wasn't sure. thanks for the help. Im building a guide out of the process, ill be sure to throw your name in there
Old 03-23-2012, 02:58 PM
GrayPony
GrayPony's Avatar
There are many guides out there already...
Attached Thumbnails Fog light wiring-fog-wiring.jpg   Fog light wiring-foglites.jpg
GrayPony is offline
Old 03-23-2012, 03:16 PM
rocket fuel
Are those the whole guides? I plan on doing a pic heavy guide, and if if there is one better then i will take if off but i feel it will be helpful.
Ford_Dude
09-15-2015 03:25 PM
jaiidutch
09-14-2015 10:29 AM
cbird1177711
09-03-2015 08:43 PM
amandahchase
09-03-2015 10:09 AM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: Fog light wiring
