Any DIY fix attempts for this? mycolor color choices busted, headunit issue D:
I am afraid of what this could turn into for a couple of simple issues - but, randomly, the color choices for MyColor stopped functioning properly for the ambient lighting (such as the footwell, door sills, cup holder etc all linked together). still works normally for the gauge / cluster.
a couple of colors dont work at all, a couple of colors select the wrong color.
randomly, the head unit has started defaulting to AM radio 600 instead of aux/fm, whatever I left it on last.
any thoughts on things to check, try? should I start simple and try a battery reset / check fuses?
If this is a wiring issue I'm afraid of what it could turn into. bit tired of leaving my car at the dealership. : P
Arg. I really loathe the idea of my interior being ripped apart and the wiring fiddled with and my car being MIA while they figure it out. it's been my experience in the past that the more you rip apart interiors, the more rattles you run into, and ultimately end up just 'dealing with them'. :/
I hear you though - any diy attempt is likely futile and I'm prolonging the inevitable. This car has been in the shop more then any of my past 6 cars combined. they'll probably tell me these issues cannot be replicated first and I'll have to find a TSB that clearly describes the problem exists and has a documented solution to follow. /vent : P
Not sure if this would help....wiring schematics.
http://iihs.net/fsm/?dir=710&viewfile=089
This looks like where you want...
http://iihs.net/fsm/?dir=710&viewfil...or%20Lamps.pdf
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
