3D Carbon Fog light grille
I'm going to have the 3D Carbon center-mount fog light grille installed on my 2012 V6 (along with an appropriate bumper cover), and the installer said they were going to splice the lights in so that they come on with the brights.
I'm considering having them not hook the lights up at all so that I can do it different (a dedicated toggle switch that lets me turn them on when I want them to come on).
Has anyone else done this, that can provide tips on how best to approach this?
I used an aftermarket kit from starkeyproducts.com that includes the fogs, wiring and replacement light switch. You can also purchase only the wiring loom and switch. You pull on the switch to turn on your fogs. Your fogs do not shut off if you run your brights. You also get to use automatic lighting already built into your Mustang ( that clear square object in the center of your dash, near the front glass). Set the headlight switch fully clockwise and your headlights come on, whenever there is not enough light, or when you turn on your windshield wipers (Law in California).
OP wanted a switch to turn them on and off when he wanted them on or off. Lots of people want to be able to control their fogs independently of their headlights. I don't get the "should" part of your response. The fogs should do whatever OP wants them to do.
jsimmonstx: the quality of the wire loom is very good, however, it presupposes you have the OEM fogs for the V6. If you have the V8 fogs installed, you may need to have the fog connectors modified. As I have not seen your bulb connectors, I do not know if they are the same as mine. Of course you can build the loom and add a SPST switch yourself.
By next Saturday, I *should* have the car back (they're also putting on a Cervini hood, a 3D Carbon body kit, and Guardsman Blue 10-inch stripes).
09-25-2015 09:06 AM
