08 Mustang Clutch Issues, Need Help : (
I have been having issues with my clutch pedal for some time now. Basically what it started out doing was sticking to the floor, I would be able to pull the pedal up with my foot and it would act normal for the rest of the day but then the next day it would be back down on the floor.
I had the clutch master cylinder replaced in hopes of fixing the issue but it didn't really help at all. Now a few weeks after the install my clutch is completely stuck on the floor, I have about two inches of play between engaged and fully pressed in. I am thinking I need to replace the whole pedal assembly, my question is has this happened to any of you guys and how would you recommend fixing it?
I was looking over this thread as it sounds like my problem, but I don't know if I can use that pedal assembly on my car (2008 v6) https://mustangforums.com/forum/5-0l...issue-fix.html
Jskeezy84
09-08-2015 01:40 AM
