Help deciding on next mod
I've been thinking, and 3 things come to mind.
-Lowering springs. Problem: the Roush body kit would cause me to scrape a LOT.
-Longtube Headers. Semi-problem: I would have to cut my current O/R H pipe to fit longtubes.
-Cams. Semi-problem: Girlfriend says they're too expensive
SO, I come to you guys. Are there any other mods that I should consider? I'm mainly interested in power adders, and my budget is limited, although I am pretty good at coming up with cash when I need to.
Good idea to keep things open, but on the other hand if YOU want it and YOU can pay for it, then do it. No one else should care. I'm nearly 18 and as much as my dad likes to intervene he lays off if Im paying for it, and everything recently I've done I have paid for and I have had all the freedom in the world Way it should be!
Anyway, my friend who has a built 4.6 with a Saleen supercharger running 12 lbs of boost is a big fan of nitrous. He said he likes it more than his supercharger. Anyway, it's not too expensive and although it isn't there all the time, it's a big boost when it's used. As far as refilling tanks, you can rent a big tank from somewhere close by here and get your nitrous for practically nothing.
