So I am trying to replace my TPS right now and this is the dumbest problem I have ever had, I can't get the electronic plug in to come off. It will not unplug no matter how much force I use, any tips? I kinda need my car so I can leave me house lol
Ok, I am on hour 3 of trying to get this off and it will not budge, friend of mine said to use WD-40 to loosen it up but will the harm the plug in or anything?
Should be able to pull back the red clip, and then use your thumb to push down near the center where the red clip was covering. Wiggle back and forth. You can use WD-40 if needed, just try and wipe things off with a good natural cleaner when you're done.
Got it off finally but now I have a bigger problem. One the old screws broke off flush inside the throttle body X_X I am so furious right now
Some of this threads give me a huge grin on my face
Simple fix.
Heat it and then use lock pliers and unscrew it :P Sometimes you have to relax with you do things, frustration is just going to make things worse. :P
