boost gauge and m90 roushcharger question
It work man). It boost around 10 psi, my gf who filmed said she saw 11 on high rpm in 3rd, thanks alot i followed ur picture, only beef
I had is the tube from the fuel thing were
Bigger and floated on my t. I used tie wrap to make them tighter and a bit of
Black tape around the tube, one thing fixed so im happy!
Oh and that m90 sounds BAD ***. I can't hear my centri hardly at all... mostly at idle or its bypass valve "PSSSH" when shifting
It the cobalt wide band, i have the same brand for my air fuel but
It only illuminate for now, im missing the oxygene sensor in the exaust, you should see my volt meter, it so ugly and not even working Had to put something in the hole
Since i only had two gauge....yah the whine is pretty damn loud, roush charger are lloud and with the cai and the huge light machined crank pulley, it make everythings spin so fast and make it sound impressive!
It sounds sweet! I would get a proper size T fitting for the vacuum hose, you don't want that popping off the fuel pressure regulator. You can get the plastic T fitting in the picture I posted at a hardware store or auto parts store.
I just ordered that autometer cobalt boost/vacuum gauge. I have an autometer gauge, but it's not the cobalt. It had an incandescent bulb, which sucked and burned out. I tried some led bulbs, but they never worked right and also burned out. So i've been driving around at night not able to see my gauge.
Galactic
04-29-2019 02:56 PM
