Those with Koni str. t shocks- Got a question
I'm starting to feel like all I post in here are issues I keep having, so I apologize in advance. Anyway, cleaning up under the car today and noticed this happening on my shocks:
Paint's just flaking off? And it seems that is rubber under where all the paint is coming up(part of the bushing?). This just started within the past few weeks or so, because I've never noticed it before. The exposed part seems to be a bit beat up as well. I think you can tell from the pics. Is this common, normal?
Mine did that too, on the driver's side. I was able to spin the sleeve a bit to where it had more clearance in that spot. I cleaned it up and covered the spot with some touch up clear so it wouldnt get any worse. After it dried I spread some super lube over it so if it did have contact again, maybe it wouldn't jack it up anymore. After thinking about it, with that piece being rubber and painted, I don't see how it wouldn't do this after a little while. Weird that they would paint the bushing? I've had them in for about 3500 miles so far.
I dig 'em. I have them paired with the steeda sports and the ride is great(and we have some pretty jacked up roads around here). I ended up getting a defective strut that squeaks and squeals horribly, but Koni has sent me out a replacement. If I ever get any time to swap it out, I will be happy
One good thing about the Koni's is that they are adjustable from under the hood and inside the trunk. Some brands of adjustable strut/shocks are only adjustable from crawling under the vehicle.
