07 SGT steering wheel vibration
I need some help. I have numerous threads for weeks and have replaced parts to no avail. This is what I have and my problem. I have a 2007 SGT with a Kennebell supercharger with 22,000 miles. I have a pretty aggressive shake in my steering wheel from 40ish and up. I have replaced rotors, brakes, tires, had tires balanced 3 times, had alignment done, checked for clip which were removed when rotors were replaced. Checked wheel bearings and tie rod ends. I run 18" Foose Nitrous wheels with hubcentric rings (just bought those to see if it would help, nope). I watched the guys balance my rims all 3 times and had no issues so I am guessing not a bent rim or they would have had issues with balancing. In saying all this. What else can I do? Thanks!
Does this happen while braking?
Any other mods?
I've seen axles going bad at 15k before.
Any vibration from 10-30mph?
Post a video.
From what you stated, you covered most of it. Though you can balance wheel/tire even with a bend.
Are your wheels staggered, if not, you could try moving the rears to the front, at least to see if there is a wheel bend problem with the fronts?
Another possibility are the struts, bad struts could cause steering wheel shake.
BTW - I'm having occasional steering wheel shake, and I'm also in the process of chasing it down, it's a pain.
Vibration when cruising or braking?
If not when braking, throw out anything brake related. Alignment issues generally don't cause vibrations either.
I would suggest making sure your wheels are straight and having your tires checked with a roadforce balance machine.
That's what I'm hoping isn't the issue. We glanced at the driveshaft and steering but haven't looked in detail. That will be soon, thanks.
Have the tires balanced on a RoadForce machine. I had 4 new wheels/tires balance perfectly on a standard spin balance but still had an issue. WHen the same shop did the RoadForce they found a defective tire with a bad belt. Tirerack shipped a new tire and it did the trick.
If it goes away on braking, something is loose in the steering linkage, most likely a tie rod end. There are inner and outer tie rod ends. Many people forget to check the inner one. The braking has the effect of removing the play in the sloppy joints of the steering linkage. So, that's why the vibration goes away on braking. Bushings can do it too, but vibration due to bushings and strut problems usually don't go away on braking. Also, pretty much every other problem the group has been talking about does not go away on braking.
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
09-08-2015 11:50 AM
