Sponsored by:
Sponsored by:
Removing etched in water spots
Old 07-06-2012, 10:47 AM
siggyfreud
siggyfreud's Avatar
Originally Posted by BigDinTexas
Yeah, I saw that recently... I've been itching to get them, but trying to justify the cost when I still have a whole container of the Bar Keepers Friend in the garage... LOL...
Don
Haha yeah I hear you. Not cheap, but certainly good stuff. I haven't gotten to use the glass polish stuff yet actually. Hoping one of my friends will need it soon.
siggyfreud is offline
Old 07-06-2012, 10:54 AM
superslow86
superslow86's Avatar
You will not be able to achieve this by hand you need a DA like a PC7424, Gritos or Flex. You will have to use a compound like M105 or whatever compound you like and go from there. Then hit it with a polish and then hit it with a sealant to help prevent this from happening again. Good luck.
superslow86 is offline
Old 07-06-2012, 11:47 AM
09daytona
09daytona's Avatar
Not to disagree but how does he know it's etched? Clay bar would be the 1st and most non-invasive method. I really can't see recommending someone start off with 105.
BTW, if you do need to go the 105 route, 3m Perfect-It is much better cut and pricewise
Last edited by 09daytona; 07-06-2012 at 11:50 AM. Reason: Quoted the wrong post. Now it's all screwed up.
09daytona is offline
Old 07-06-2012, 11:49 AM
09daytona
09daytona's Avatar
Originally Posted by stealth32
porter cable with meguiars 105 and 205 works wonders
05xrunner
05xrunner's Avatar
did you read what i wrote..I said IF its water etching clay will not do anything.
05xrunner is offline
Old 07-06-2012, 12:40 PM
BlueBellThunder
BlueBellThunder's Avatar
I'm assuming it's etched because when I was waxing it the water spots weren't going anywhere. So I guess I'll take your advise and try the clay bar first and see what kind of results I get and take it from there. I dont plan on doing it anytime soon, its just to damn hot.
Thanks for all the replys.
BlueBellThunder is offline
Old 07-06-2012, 12:41 PM
BlueBellThunder
Also I don't know if this helps but you can only see the spots close up
when looking at an angle.
Old 07-06-2012, 02:21 PM
05xrunner
05xrunner's Avatar
hard to say..Just get yourself a clay kit they are cheap like 16bucks either Mothers or Megs and clay a small section to see if they start to come off..if they dont they might either be etched in or you may need a more aggressive clay. But if they remove some and not totally i would say more aggressive clay will do it. but if it doesnt remove anything then you will need to buff the paint.
Old 07-06-2012, 03:46 PM
Toxix
Toxix's Avatar
Meguiars 105 - Cutting agent, it is an abrasive, will definitely remove the water spots.
Word of advice when using it: Remove it as soon as it has been applied.
Toxix is offline
Old 07-06-2012, 03:56 PM
05xrunner
05xrunner's Avatar
megs ultimate compound would probably be better for a first timer. it has a longer working time, doesnt dust as much and has close to the cut of 105 so it will get the job done.
Quick Reply: Removing etched in water spots
