Cam's on DD?
I also run the Detroit Rockers on a DD. The car runs just like it did when it was stock, except for the awesome idle and power gain! Either cams would be good. I obviously can only speak of the Detroits, but many guys here run the HotRods and they're fine. Just get a tune from a good reputable tuner.
In my set up.. there's a little loss of low rpm torque and about 2mpg difference... stop and go is a little more annoying.. but not that big a deal.. Sound is awesome... and my shaker actually "shakes"
I got a pair of hot rod cams barely 1500 kms on it for sell with the phasers if u ever need, only probleme im in canada quebec near Lacolle/napierville Border line, would need to double
Check for shipping fees
I really want a set of cams for the cool lope. However I've seen a few Stang that have to keep reving at stop lights just to keep the idle up. This the only reason why I hesisatate. I read that changing the stock gears is suggested with the Detroit Rocker to avoid possible idle issues. I want drive ability even in stop and go traffic.
I was definitely afraid of ruining my drivability when I installed the cams, but was pleasantly surprised when my drivability got better. Couldn't be happier with my set up!
Generally it's the tune when guys talk about bucking and stalling. When I first had my detroit rockers installed my car would idle up and down and die. And it would also buck. I had to take it to brenspeed where they got the issue takin care of. Not all cars are the same so what tune works for your might not work for yours even if the mods are the same
junior04
09-28-2015 10:53 AM
