Whenever I turn the wheel this a little bit right, or all the way right i hear a little nosie, but it more like i feel something moving, like it worn out, some shops can't find it, they said it was the driver side wheel bearing, i replace 2 times and still the same feel. any idea
Can you describe what the noise sounds like?
Do you have oversized tires in front?
Can you make a vid of the noise when it happens? Like a gopro stuck outside looking at the offending wheel when turning?
Originally Posted by wcgman
Turn left more.
This wins the "I have nothing technically worthwhile to say but i have a funny smart azz response" award; one that I often attempt at attaining, also. Good one.
it sound like somthing is worn out, i do have 20''x 8 on the front, cant find anything rubbing, i have change the strut, lower control arms, outer tie rods and upper strut mount, no nosie or do i feel anything when turning right or going straight
It's definitely not a wheel bearing issue. When wheel bearing starts to go bad, you hear a humming noise, and the noise gets louder as the speed increases. Could be a ball joint issue.
