Last edit by: IB Advertising
Browse all: Ford Mustang Powertrain Guides
- Ford Mustang V6 2005-2014: How to Replace Spark Plugs and Wires
Step by step instructions for do-it-yourself repairs.
Replacing spark plugs in an '07 V6
Does anyone have to a guide for a how to? Also, would I need the special tool to remove them if I broke one? The GT ones look a lot father down and harder to get at so that's why I was wondering. Thanks.
The only thing to watch for is when you put them back in. HAND THREAD them in to start. That way you are sure not to cross thread them. A lot of guys grab the socket wrench and start wailing away without starting them by hand first and end up cross threading.
The last one on the passenger side was always the most difficult one for me. It angles back toward the fire wall and you can't see anything. So difficult angle and tight spot. I found using a wobble extension helped.
Yup. And gap them properly, using a standard feeler gauge. I think the gap is .045 .
Just use common sense when removing and putting them in. Like dont pull on the spark plug wire on the wire part (pull the boot), remove carefully, install carefully with some antiseize on the threads, etc.
