Manual trans scheduled maintenance makes no sense
Looking by accident at the wrong year I discovered something I don't understand. Looking at the schedule maintenance the 05 and 06 manual trans fluid should be changed at 60k but the 07 at 100k yet they use the same fluid and capacity, why?
In 08 they switched over to Mercon V with the same capacity yet you only get an extra 5k miles between changes compared to the 07.
So why is the 07 different from the 05 & 06? Is the trans different?
2005, 2006
Motorcraft MERCON ATF
3.2 quarts (3.0L)5
Change at 60k,120k
2007
3.2 quarts (3.0L)5
Change at 100k
2008, 2009, 2010
Motorcraft
MERCON V ATF
3.2 quarts (3.0L)5
Change at 105k, 150k
2005, 2006
3.2 quarts (3.0L)5
Change at 60k,120k
2007
3.2 quarts (3.0L)5
Change at 100k
2008, 2009, 2010
Motorcraft
MERCON V ATF
3.2 quarts (3.0L)5
