Looking into the Boss intake for GT
I'm interested in doing some airflow upgrade to my 2011 GT 5.0, and I'm contemplating the Boss intake. The mechanical side of the work is nothing new to me, but the computer side I'm ignorant of. Ford and every other vendor recommends custom calibration, which I'm assuming is going to require an electronic tuning kit and some time on a dyno. I've never gone through the effort to dyno tune and I've never attempted the electronic stuff.
What and how much work should I be expecting for the calibration?
What are the consequences of not doing the dyno and electronics work?
It should be rather painless. You just need a hand-held tuner (AmericanMuscle or Brenspeed are good bets) with the appropriate tunes. You would simply install the Boss manifold, plug the tuner into the OBDII port, and load a tune. No dyno necessary
It's a shorter shot from the manifold to the cylinder, it can't possibly hurt torque enough to notice/care. It allows for higher rpm capability. The big difference is what happense after stock peak hp (right around 6,500 to 6,600 rpm).
Stock, hp drops off quite a bit, but with the Boss intake manifold, hp just hangs there until WELL after 7,000 rpm....and if you're tuning anyway, you're going to have more torque than stock....
