2007 Mustang GT, P2111, P2110, P2101, P2104
Now I'm sick to my stomach, I broke the retaining clip to the throttle body actuator to my 2007 Mustang GT, when I went to replace the connector I now get these codes P2111, P2110, P2101, P2104, It was running fine before I replaced the pigtail. When I first turn the key on I get 6volts briefly then goes to zero. Can someone please help?
Here is a dump of the scan.
Make:Ford Year:2007
----Confirmed Codes Scan Report----
0 Confirmed Trouble Codes:
----Pending Codes Scan Report----
4 Pending Trouble Codes:
1:P2111 - Powertrain Issue
Throttle Actuator Control System - Stuck Open 9
2:P2110 - Powertrain Issue
Throttle Actuator Control System - Forced Limited RPM 9
3:P2101 - Powertrain Issue
Throttle Actuator 'A' Control Motor Circuit Range/Performance 9
4:P2104 - Powertrain Issue
Throttle Actuator Control System - Forced Idle 9
----Freeze Frame Scan Report----
P2111 caused freeze frame data: Throttle Actuator Control System - Stuck Open 9
Monitor Status Since DTCs Cleared: 0
Fuel System Status: Open loop due to insufficient engine temperature
Calculated Engine Load Value: 0.0 %
Engine Coolant Temperature: 64 °C, 147 °F
Short Term Fuel Trim Bank 1: 0.0 %
Long Term Fuel Trim Bank 1: 0.0 %
Short Term Fuel Trim Bank 2: 0.0 %
Long Term Fuel Trim Bank 2: 0.0 %
Engine RPM: 0 rpm
Vehicle Speed: 0 km/h, 0 MPH
Timing Advance for #1 cylinder: 10.0 °
Intake Air Temperature: 65 °C, 149 °F
Mass Air Flow Rate: 0.00 g/s, 0.0 lb/min
Absolute Throttle Position: 83.1 %
O2 Bank 1 - Sensor 1: 0.000 V, 0 STFT %
O2 Bank 1 - Sensor 2: 0.000 V, 0 STFT %
O2 Bank 2 - Sensor 1: 0.000 V, 0 STFT %
O2 Bank 2 - Sensor 2: 0.000 V, 0 STFT %
Run Time Since Engine Start: 0 seconds
Fuel Rail Pressure (relative to manifold vacuum): 515.317 kPa, 74.7 PSI
Commanded Evaporative Purge: 0.0 %
Fuel Level Input: 0.0 %
# of Warm-ups Since Codes Cleared: 0
Distance Traveled Since Codes Cleared: 0 km, 0 mile
Evap. System Vapor Pressure: -34.25 Pa, -0.138 inH₂O
Barometric Pressure: 98 kPa, 28.9 inHg
Catalyst Temperature Bank 1 - Sensor 1: 64.3 °C, 147.7 °F
Catalyst Temperature Bank 2 - Sensor 1: 64.3 °C, 147.7 °F
Monitor Status this Drive Cycle: 0
Control Module Voltage: 12.185 V
Absolute Load Value: 0.0 %
Commanded Equivalence Ratio: 0.999
Relative Throttle Position: 66.3 %
Ambient Air Temperature: 63 °C, 145 °F
Absolute Throttle Position B: 87.8 %
Accelerator Pedal Position D: 18.0 %
Accelerator Pedal Position E: 28.2 %
Accelerator Pedal Position F: 17.6 %
Commanded Throttle Actuator: 9.0 %
Make:Ford Year:2007
Engine RPM: 0 rpm
Disregard
I figured it out, when I replaced the connector with the one from the junkyard for $5 instead of the one from Ford for $49.95 the colors to the pins were switched...
D'oh!! Mental note, make sure pins and colors are the same..
Now I can do the happy dance.....
NorthAmericanTuning
03-18-2016 11:21 AM
