Sponsored by:
Sponsored by:
dump it or powershift it (burnout)
Old 10-16-2012, 11:07 AM
siggyfreud
siggyfreud's Avatar
Other than the slippage as you let off in second, I don't think you're actually working the clutch that hard with a second gear burnout. I imagine the times when it slips then immediately hooks is when you'll see the most brutal wear on it.
siggyfreud is offline
Old 10-16-2012, 11:25 AM
Riptide
Riptide's Avatar
Originally Posted by Mishri
not going to use my M&Hs? did you buy the tires or just planning to before next season?
I have some nitto NT05r drag radials. I may use your M&H though. I haven't decided. Yours are already mounted which means a straight swap of the two wheels. If I use mine I have to get the street tires off and mount the drag radials. If I had to do it over again I would've kept my old bullit wheels and spent the money on a set of 15x8 and a slick. The enkei wheels I have are awesome but the money would've been better spent on some racestars or bogarts.
BTW what's up with this 3500'ish post nonsense. I hardly show up here for months and you still haven't caught up. I has a disappoint. You need to work on your SPAM skills.
2nd should want to slip more than 1st. I do wonder however how my 2nd gear with 4.10 compares to 1st gear in a 3.31 or 3.55 equipped car.
Riptide is offline
Old 10-16-2012, 04:18 PM
Andy13186
Andy13186's Avatar
ive tried starting a burnout in 2nd and clutch didnt catch and it burned bad
it just slipped while my car redlined for a sec (03 mustang) smelled like my car was on fire
my 2011 i went from 1st to 4th accidently during a burnout and it slipped also
Andy13186 is offline
Old 10-16-2012, 06:23 PM
Riptide
Riptide's Avatar
How is your car geared? If it is geared pretty tall then the 2nd gear dump is more likely to spin the clutch.
If mine won't do a burnout in 2nd even with water on the tires then there is not a lot of sense in tracking it as it sits. May as well plan on doing the clutch first at that point.
Riptide is offline
Old 10-16-2012, 06:45 PM
Andy13186
Andy13186's Avatar
if your referring to me, my 03 mustang was 3.27 my 2011 mustang is 3.31
In my 03 I revved to 4k or so in 2nd while rolling like 3 mph , dropped clutch and floored it and no catch, just pure clutch burn, on street tires
Old 10-16-2012, 10:23 PM
Diabolical!
Diabolical!'s Avatar
I only have 3.55s and I have no trouble dropping the clutch in second and roasting the tires.
Diabolical! is offline
Old 10-17-2012, 09:43 AM
Andy13186
Andy13186's Avatar
you also have a macleod rxt clutch
Old 10-17-2012, 10:57 AM
Diabolical!
If you're drag racing, the stock clutch is going to die soon enough anyway from launches alone.
Old 10-17-2012, 12:20 PM
Riptide
Riptide's Avatar
This is sadly true enough. I'm hoping it lasts long enough for me to get some attempts in before I smoke it out there. It might be OK for a while. People in the 300whp range have had the stock clutch last a long time out there and I'm not making THAT much more power.
I am planning on doing the clutch but since it is a huge job that will take me a long time to do. I may end up waiting until the tail end of the racing season next year to track the car. That way if I break it then I'll have a lot of time to work on it over the winter when the car would be down either way.
Riptide is offline
Old 10-17-2012, 01:06 PM
Andy13186
Andy13186's Avatar
I would say power shifting is easier on the clutch , from my personal experiences
In my 2003 mustang i tried the 2nd gear start and it burned the clutch like i described
i also did a massive powershift burnout going to redline in 1st while spinning the tires at like 4 mph then hitting 2nd and the tires kept spinning for like 100 feet , no brakes, pic below
this was 1st gear until 5 mph (about 5 feet), then 2nd gear , bone stock 2003 mustang no brakes, clutch caught fine here
Quick Reply: dump it or powershift it (burnout)
