Left Turn Signal Not Working - But Bulb Not Burnt Out?
When I unlock my '07 GT, the left middle bulb turns on, however when I activate the left turn signal, only the front light flickers - not the rear.
Anyone know what might be causing this? I figure it's probably a fuse but I'm not completely sure..
http://iihs.net/fsm/?dir=40&viewfile=Turn Signal, Stop, Hazard Lamps.pdf
Copy and paste the above. For some reason, my computer is breaking up the link.
Any chance your car has been in the rain a lot lately?
Your taillights and brake/hazard/directionals work off two separate filaments in the same bulbs. All your taillights might work, but that doesn't mean the filaments that run the other lights are okay. Only the outer two lights on each side are illuminated for brake/hazard/directionals.
It's was likely a fuse (in the engine bay). I had a similar issue of a fuse that was removed and not replaced when service was complete. They have a crossover wire on one of the bulbs (out of the 3) for brakes and running lights as a safety, but they can't do that for turn signals. Unfortunately the fuse diagram doesn't label the rear right and left turn signal/hazard/brake, but uses something obscure... just looked up an email I sent out... "SJB#5", which is fuse 59, this is for the passenger side only, not sure which fuse is for the driver side.
Diode Dynamics
28
05-26-2022 12:02 PM
