Sponsored by:
Sponsored by:
super frustrated, bama tunes/am, anyone have some insight/things to try?
Old 10-21-2012, 02:45 PM
  #21
Entaille
Entaille's Avatar
that's good to hear that that is normal. still bummed that this whole mess was created trying to fix something that is normal though ;(
I am waiting a little bit on throwing the stock intake/tune on, I want to see what AM/Bama wants to do on Monday for next steps
.. not that I am glad you went through that, but it's refreshing to read that someone else had this issue as a tuning issue. kinda helps reaffirm my thoughts on a bad tune causing this. maybe a bad tuner device even while loading the tunes, the thing did crash during a firmware upgrade and I had to re-do that. seemed to work, but maybe it corrupted something ..
Entaille is offline
Old 10-21-2012, 03:17 PM
  #22
a_lopez1975
a_lopez1975's Avatar
Subscribing to this thread to see the outcome. I hope all goes well.
a_lopez1975 is offline
Old 10-21-2012, 03:35 PM
  #23
Mr2013GT
Mr2013GT's Avatar
What are the coldest temps you see up there?
Mr2013GT is offline
Old 10-21-2012, 03:42 PM
  #24
bigmike06gt
bigmike06gt's Avatar
If nothing else go to The Mustang Shop near Seattle and get a proper dyno tune put on. That way they see everything on the car and might be able to solve all your issues. I went there about 3 monthes after I got my Bama tunes and they got another 18rwhp over and above what I got from the email tunes.
bigmike06gt is offline
Old 10-21-2012, 05:37 PM
  #25
Entaille
Entaille's Avatar
I've thought about that, but I really like the warranty with BAMA.
coldest temps .. in severe cases, in the teens.. as of late? around 45.
Entaille is offline
Old 10-22-2012, 01:56 PM
  #26
Entaille
Entaille's Avatar
well BAMA hasn't replied to my email update, they must be busy, I hate hounding them for info but .. hey, when you can't use your car, it'd be nice to be prioritized a little.. : )
Entaille is offline
Old 10-22-2012, 01:59 PM
  #27
Entaille
Entaille's Avatar
SCT replied to me (reached out to them for input too), pretty quick to reply.. they suggested that some other Mustangs having this issue / caused by a misfire need to have the crankshaft relearn procedure performed by Ford.
sounds like I should install the stock intake and tune to see if it does it on that to eliminate the tune/map as a possibility, but I dunno. will call BAMA in a bit to see what they think.
fun times ahead..
Entaille is offline
Old 10-22-2012, 02:08 PM
  #28
Entaille
Entaille's Avatar
Ahhh I guess the general bama email address is having issues at the moment .. forwarding the info to a direct email address. It may just be that I'm tuned on the wrong steeda intake at the moment .. hopefully that is all that it is, that would be an easy fix.
Entaille is offline
Old 10-22-2012, 02:57 PM
  #29
AMDanBailer
Former Sponsor
AMDanBailer's Avatar
Hey Entaille,
I'm really sorry about all the issues you've experienced with your tunes. This sounds really odd because we've dialed our tunes in so good that in most cases they don't even require a revision though along more then one. However it sounds like we definitely dropped the ball here and I'm sorry it happened to you.
I'm glad to hear that you've got in direct contact with a Bama team member however I want to make sure you're taken care of. Shoot me a PM with your order number included and I'm going to get you in direct contact with my head tuning specialist Mike Wilson. I'm confident he'll get you squared away very quickly!
I appreciate your patience, hang in there! You'll be enjoying your tunes in no time.
-Dan
AMDanBailer is offline
Old 10-22-2012, 03:23 PM
  #30
Derf00
Gentleman's Relish
Derf00's Avatar
fun times ahead..
Don't know specifically about the 2011+ mustangs but most newer cars (and especially those with throttle by wire or adaptive learning) need to have the idle and fuel trims relearned in order have the car idle correctly and have throttle tip-in be calibrated correctly.
I have never heard of a Ford Crankshaft relearn procedure? Maybe they are calling something else these days.
Derf00 is offline
Quick Reply: super frustrated, bama tunes/am, anyone have some insight/things to try?
