Pype Bombs VS Pype Muffler Delete
Does anyone know what the difference between these two axle-backs is? The Bombs seem to have large tips unlike the Muffler Deletes. Other than that, they look to be exactly the same. I don't think the tips would change the sound much, but they would definitely look better.
Thank you!
Pype Bombs
http://www.americanmuscle.com/pypebo...back-0510.html
Pype Muffler Delete
http://www.americanmuscle.com/pypes-...axel-back.html
Thank you!
Pype Bombs
Pype Muffler Delete
Nevermind... Called AM and they say that these are essentially the same thing...
But, does anyone know how these compare with the Boom Tubes? I had the Boom Tubes on my last car (07 Shelby GT), stock X-Pipe, no cats, and they were great.
I have the Pype Bomb catback and it has the same resonators at the end as the Pype Bomb axle back. The second one you posted appears to just be straight pipes, and not even a resonator at the end. I assume the second one would be louder for that reason?
Thank you!
Pype Bombs
Pype Muffler Delete
Thank you!
Pype Bombs
Pype Muffler Delete
The Pypes bomb will be similar to the exhaust you mentioned you had on your previous Stang!
I hope this helps. Let me know if you have any questions!
-Dan
I have the "Bombs" and really like them.
I think the deletes would sound like crap. I drove my car (across a parking lot) with nothing on it when I was switching from MagnaFlows to PypeBombs. That's essentially what the deletes are. It sounded like a diesel idle
The difference between the two is that the Pype Bombs have resonated tips while the Muffler deletes are straight pipes. In order to achieve a similar setup to the Boomtubes/cat delete you'll have to change out the midpipe/delete the cats again. Boomtubes and Pype bombs are VERY similar setups.
Thanks for the replies. I'm currently running stock X-Pipe, no cats, stock GT500 mufflers. I'm going to be swapping those out for the Pype Bombs or Boom Tubes soon... I loved the way it sounded on my last one... abnoxiously loud outside but not overbearing inside.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
