Whats the DEAL!? My Gt has no Bottom End Anymore!
To help clean the injectors, you could add about half a can of Seafoam to the tank of gas the next time you fill up and see if it could help... If nothing else, it will help with some of the carbon build up in preparation of changing the plugs...
Also, when was the last time you cleaned your TB? I could see gunk and sludge build up causing the butterfly to stick when you try to accelerate, causing a perceived loss of low end torque... Once it gets passed the build up then the butterfly is able to open up more smoothly, helping the car feel like it woke back up... Just a shot in the dark, and you probably already checked that, but just thinking out loud, so to speak.
Good luck.
Don
Good luck.
Don
Don,
Thanks for the suggestion. I just actually ran seafoam though the tank on the last fill up an cleaned the TB about 2 months ago now. Those were the first two things I tried, but are a great suggesting and the seafoam will help with the plug removal...I hope.
I'd recommend ordering the Lisle tool from Amazon or eBay before hand and have it ready... I did when I planned on replacing my plugs on my 05, but ended up not needing it and selling it on eBay when I traded the car in.
Don
