Engine light flashed a a few times then went off?
I had this before with my 06 GT. The the flashing check engine light for about 10-15 seconds ( I think mine went into partial limp mode as well on the highway ) This is caused by a misfire. Make sure that your plugs are good. My problem was that there was a small puddle of water sitting by my injectors that was seeping through I'm pretty sure.
flashing light should be a misfire... did you check where your injectors are for any build-up of water?
My car is actually dipped. It peels off like a wrap when it dries. Unfortunately I had body damage recently and I'll need to redo it :-\
Have a great day, everyone!
Crystal
I actually had just shifted from 6th to 3rd at 60 mph or so, gave it a bit of throttle then maintained RPM, then engine braked slightly then upshifted to 5th and may have been engine braking slightly, i think i was maintaining RPMS or very light engine braking in 5th when the light came on a few times. It was odd
It may have been just thinking you were misfiring due to rapid decel and engine break going into the corner. Causes a lot of unburnt fuel to go through the exhaust, the engine can interpret the high fuel level as misfiring.
