Installed Shelby Quad Exhaust need some advice
I installed the 2013 quad exhaust on my gt mustang and I was hoping for a little deeper sound. It definitely sounds better than stock, but it has a little popping sound that I really don't care much for. I was wondering if adding a h-pipe or the boss quad exhaust setup or removing resonators would help? Any advice to make my exhaust more deeper tone and take out the pop/raspy sounds?
Thanks
Thanks
the popping is pretty standard with any exhaust setup.. mainly at decel/engine braking and sometimes on a good solid aggressive high rpm shift.
your car already has an H pipe, although it's a little restrictive.
most of the sound is due to the pipe sizing and the mufflers.. and H pipe vs X pipe sound a lot different, too. the resonator's typically quiet the system down and remove a little rasp, straight pipes would be a little raspier. I would personally look into an X pipe and slightly larger mid pipes too.
my two cents.
my two cents.
For those of you wanting the pics...here they are.
https://mustangforums.com/forum/2005...-the-13-a.html
I had the Pypes X-Pipe system installed, resonator delete and Flowmaster A/T axlebacks
I also have a box of ST BBK headers sitting in my living room. They were going to go on the 2011, but 24 hours after the mod was done, I traded it on a 2013 (but I beat the living hell out of the car for 24 hours.)
panic
08-25-2015 09:34 AM
08-18-2015 03:39 PM
