Fuel stepper motor going out - Will gas warning light still come on?
sorry it took so long to respond.. the cost is actually $90. they said it took him less than an hour from taking the instrument panel out to having it back to gethere and working. sending you a PM with the info.
Thanks again for the info! Greenville, SC is about 2 1/2 hours from me. I will definitely keep them in mind, once I decide to get all of the stepper motors replaced. ;-)
its probably your stepper motors in the gauges. My brother had the same problem with his oil level gauge in his 05 v6. He did a how to write up on replacing the stepper motors.
https://mustangforums.com/forum/2005...r-cluster.html
Good luck, Kev!
Good luck, Kev!
Good luck, Kev!
Good luck, Kev!
According to my cluster:
Fuel is beyond empty at all times, the needle hangs down most of the time.
Engine temp is ice cold at all times.
Battery is dead at all times.
Engine idles at -500 RPMs at all times
Oil level is over flowing at all times.
I've been in this position for over a year now, just got the stepper motors in from Amazon and plan to do the fix in the next few weeks.
The gas light does still turn on at the appropriate time and if you have the message center, it will warn you when you are at <50 miles.
Good luck!
Good luck!
