Sponsored by:
Sponsored by:
Clunking noise after lowering
Old 02-07-2013, 08:24 PM
BrandonsBlueStang
BrandonsBlueStang's Avatar
Default Clunking noise after lowering
I have a really loud clunking noise coming from the front of my car that was not there before I lowered it. Every time I hit a bump it sounds like something is about to fall off. I can also push down on the front of my car and make the noise. I did all the work myself and am 99% sure I did everything right but I guess it's possible I missed something. I replaced the shocks and struts with Tokico HP series shocks/struts from AM. I used the Eibach Pro-kit lowering springs from AM as well. I am taking it to get it aligned in the morning, I'm sure they'll be able to help me figure it out but if it's something I can do tonight I'd like to do it.Any help is appreciated.
Here's a video of me pushing down on the passenger's side front fender.
BrandonsBlueStang is offline
Old 02-07-2013, 10:15 PM
BrandonsBlueStang
Fixed it Strut tower wasn't tightened down tight enough and was causing the rattle. Thankfully, an easy fix.
Old 02-08-2013, 10:27 AM
kevinmalec
kevinmalec's Avatar
Good to hear you were able to locate the cause and easily fix.
Post some pics!
kevinmalec is offline
Old 02-08-2013, 06:10 PM
Esch
Esch's Avatar
Are you referring to the 4 bolts on each side? I have J&M camber plates, and I get a "clunk" over bumps at low speed. I'm also pretty sure that I have everything tightened correctly, but I'm just under the assumption that most aftermarket camber plates will generate more noise than the stockers.
If it was those 4 bolts, then that's something I can double check pretty easily as well. Checking the nut that secures the camber plate to the strut is a bit more of a pain.
Esch is offline
Old 02-08-2013, 09:12 PM
BrandonsBlueStang
If it was those 4 bolts, then that's something I can double check pretty easily as well. Checking the nut that secures the camber plate to the shock is a bit more of a pain.
It was the single bolt on top of the strut mount. I was able to get an open end wrench in there and tighten it without taking it off.
BrandonsBlueStang
Post some pics!
Will start a different thread tomorrow with pictures
Old 02-09-2013, 01:39 PM
Esch
Esch's Avatar
That one is 21mm, correct? I know the top of the stud can be held with a 10mm socket while the nut is tightened.
Esch is offline
Old 02-09-2013, 04:32 PM
BrandonsBlueStang
21 or 22, can't remember.
Old 02-09-2013, 04:47 PM
zworld
zworld's Avatar
13/16ths works too
zworld is offline
lincolnshibuya
07-05-2020 03:05 AM
baddog671
07-26-2016 01:20 PM
UrS4
10-03-2015 06:23 AM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Quick Reply: Clunking noise after lowering
