Heat/AC only works on 4.
About a month ago my air would only blow if it was on 4. It didn't matter what the other things were set to it would just shut off it I turned it to 3,2, or 1. After some research I determined it was the blower motor resistor. A week ago, I replaced the resistor and it worked fine, easy 20$ fix. Yesterday it started the same thing, only works on 4. Did I just get unlucky and get a faulty resistor or is something causing that resistor to quit working? I know it's only 20$ but I'd like to know if I replace it again it's not going to quit working in a week. I have had the 'famous' water leak into the passenger's floor.
My blower motor does squeak occasionally, I have to turn it off and wait a little bit to turn it back on to make it stop. Not sure if that has anything to do with this problem or not.
Any help is appreciated.
If the blower is squeaking you will probably have to replace the motor assembly. Had the same thing on my dodge truck and that fixed it. The bearings in the fan motor are toast. The one for my truck was about $200. This may also be causing your resistor to go.
blvd85
11-07-2012 06:49 PM
