Future proofing daily driver for hard driving
#43
Don't neglect the little things; Low expansion brake lines (Boss 302, 90 bucks for all four); Cam Bolts for when you lower and want to save your tread; Bump Steer kit, stop jinking left/right/left etc... on bumps especially after lowering; One piece Aluminum driveshaft with a steel braided hydraulic line; Heavier Steada X-11 balljoints; ditch that stock shifter; Weather Tech floor mates, because one day someones going to drop a fully loaded 64 oz. soda. Thank you, my work here is done.
#44
Anyway: wider, stickier tires for tracks. Suspension is going to be a must, in addition to some form of upgraded brakes.
Let's talk cooling. Is the stock radiator good enough to overcome the heat generated by track driving?
What about oil. Do you autocross guys run any special oils or other fluids (differential, transmission etc.)? I did read that people like to flush the stock transmission fluid and replace it.
What part of Colorado are you in? The SCCA autocross is pretty active here. About a half dozen mustangs in different configurations run. Would love to see another one there.
I do HPDE's with PCA. I usually have my 911 out on those events. However, all marques are welcome especially mustangs.
I am co-chairing a PCA event at High Plains Raceway this weekend. Come on out and take a look around. It's too late to register for the event, but you can still get a feel for what it's about. I'm Jim Thorburn. Find me (I'll be pretty easy to find since I'm one of the chairs) and I'll show you around.
Welcome to the wonderful wacky world of motorheads!
#45
The best thing you can do to have your engine run forever is to never drive hard on old oil and never drive hard when your engine is still cold.
And I take my stang up to the redline almost on the daily. I take an off ramp that has two sweeping turns and a 1000 ft straight and it's the highlight of my day. Hitting 5500 rpm in my 4.6 and I'm not worried one bit considering there are porsche flat sixes that go up to 8000.
Am I missing something here?
OP, I'd start out with a good helmet for events. Then maybe work my way up to an intake/tune and better brakes. Not sure about the newer V6s, but I warped my stock rotors on relatively tame mountain roads in Tennessee.
#46
#47
Mechanical stress goes up exponentially in higher revving engines. The point I was trying to make was that 300hp at 5-6k rpm isn't going to wear a v6 engine at all.
squishbang
Suspension
11-02-2015 03:42 PM
dochawk
08-25-2015 08:25 AM
Figure8allday
08-22-2015 11:11 AM
