Limp Home Mode/Check engine light/loss in RPM & Gas Milage
Hi Forum, 2005 ford mustang v6 stock
The other day while I was driving withg AC on my car went into limp home mode. I turned the car off and it went away. Next day it happened agian without AC on. This time the check engien light came on as well as the limp home mode. Turned car off once more & it went away but I have had a drop in RPM 1000 down to just about 500 & gas milage seems lower. I've cleaned the throttle body and mass air flow sensor & Just changed the throttle position sensor after reading other posts on this website. RPm still sitting at 500/600. Any input would be great.
thanks
thanks
Also, did you pull the battery and go through the relearn procedure?
ShaneB26154
35
03-04-2021 04:05 AM
jpplaw
08-22-2015 09:29 PM
HIS S-197
08-10-2015 05:47 PM
