Sponsored by:
Sponsored by:
Help: High Speed Vibration
Old 06-24-2013, 07:11 AM
SON OF 68
SON OF 68's Avatar
Default Help: High Speed Vibration
I have a vibration that starts at around 85-90 and starts to get pretty violent at and a bit over 100. I also had a howl at lower speeds and found the pinion bearing to be the cause. This was replaced and the howling stopped.
Now I still have the vibration. I'm thinking that this could have chewed up the pinion bearing. My car does have a 1 piece alum DS from Steeda. I have a spring kit which is 1" front 1.25" rear. I have Steeda LCA's and UCA on it. They are both fixed, and the UCA is the fixed one for lowered vehicles. Supposedly it matches their spring kit.
I guess I'm wondering if I should have the DS checked/Balanced. I don't seem to have vibration down at lower speeds like 70 and under, which is usually where you seem to get wheel balance issues. On top of that, it all started it seems like after I installed the DS and control arms. If the pinion angle is off, how would you adjust with fixed control arm? I imagine I'd have to go adjustable correct?
SON OF 68 is offline
Old 06-24-2013, 09:51 AM
Rudolph Hucker
Rudolph Hucker's Avatar
ok do have after market wheels?
if so are you using spigot rings?
have you remove the small retaining clips that hold on the discs.
Rudolph Hucker is offline
Old 06-24-2013, 10:03 AM
SON OF 68
SON OF 68's Avatar
Well they are not the wheels that came on the car. They are the 18" CS/Shelby 350 wheel. No, I didn't remove retaining clip. Don't recall if its there or not.
Didn't have this vibration before the DS and suspension mods. Had the wheels and lowering springs first.
Old 06-24-2013, 10:49 AM
Nuke
Nuke's Avatar
The stock OE and a lot of other Ford wheels won't be affected by the retaining rings but other aftermarket wheels are. Remove the rings at all 4 wheels (or whichever has them; sometimes there's none, other times more than 1 per axle half.)
Nuke is offline
Old 06-25-2013, 09:53 AM
SON OF 68
SON OF 68's Avatar
I have OE wheels. From the looks of it, it isn't affected. I also checked the pinion angle and it's ok. I'm going to start with having the DS balance checked. Not sure what else to check at this point. At least if I check that, it's one more thing to rule out.
Old 06-25-2013, 10:29 AM
krazykevin
krazykevin's Avatar
Have you measured your pinion angle as it sits right now ?
krazykevin is offline
Old 06-25-2013, 05:09 PM
SON OF 68
SON OF 68's Avatar
Pinion angle was ok. Here's what we found. The rear U-joint was tight, felt kind of binding in certain movements. Also, the front slide was not able to move at all. They found the shaft to be balanced good once those two issues were addressed. So we'll see, next time I get it up to higher speeds. But so far, it seems smoother even around 60ish. Could be all in my head, sometimes you think you notice things when you make a repair. LOL
Thanks once again guys for the input and the suggestions. Everything always helps!!
Old 06-25-2013, 09:43 PM
cariacou
cariacou's Avatar
sounds to me like an alignment issue
cariacou is offline
Old 06-26-2013, 07:10 AM
Nuke
Nuke's Avatar
Have you had your wheels/tires RoadForce balanced? It'll pick up issues including wheel and tire defects that a standard spin balance won't. I had 4 new Goodyear tires spin balance beautiful (I insisted on watching) but still had vibration and low speed bounce. After a subsequent RoadForce balance, one of those new tires had a defective belt which wouldn't flex properly as the tire rolled with weight. The spin balance had no way of picking that up.
Nuke is offline
Old 06-27-2013, 01:46 AM
808muscle
808muscle's Avatar
I was really expecting your PA to be out. I had that same issue after installing a one piece shaft.
808muscle is offline
Quick Reply: Help: High Speed Vibration
