Fair price for a Shifter Installation?
That price is pretty solid for install.
But with that being said, I still wouldn't waste the money. I did the shifter and bracket install myself. It is easy and a fun little project. It feels good to get your hands a little dirty and do something yourself.
Make sure to buy the bracket and shifter. The bracket is probably more important to getting a better shifting car. The stock rubber POS will mess up your shifts and cause slop even with an MGW shifter.
I am on MGW's website and I see the shifter for my car. Does the bracket come with the shifter? If not, where do I buy the bracket? I don't see it as an option. Thanks.
I wouldn't pay more than $0 after having done it myself in the two hours you're quoting. The installation CD they include with it makes it incredibly simple. Seriously, don't pay someone. I just put mine on and did a load of laundry at the same time and the laundry was done when I finished installing it. This is my first manual car, and definitely the first time I've looked at a shifter, so if I can do it, you can. Just watch the video they include beforehand, then use it as your step-by-step instructions to do it yourself. It's incredibly easy. After having done this and all my own mods (listed in my "garage"), I don't know why I ever used to pay someone else.
I believe you can only buy it direct from MGW, but the price of entry is worth it, as others will chime in and tell you.
I would try it if I had a driveway or a garage. Since I moved, I don't even have my rhino ramps anymore and the apartment complex forbids people from doing work on their vehicles. I will even take the Mustang in for oil changes now . I used to do routine stuff like oil changes and new brakes. Now I just don't have a place or equipment to do it.
But anyway, does the bracket I need come with the shifter? Thanks.
Does the MGW have a bottom bracket or double bottom bracket? That and having to remove all the center section and dash. $100 an hour is standard for a Mustang shop.
Have you seen the U-Tube? It's shows step by step and it's not as hard as you think, unless you have to start removing other parts. If you can screw it up and still get to work the next day try it.
A straight driveshaft and a steel braided clutch-line will help the shifts also.
Got a friend with a drive way or garage?? MGW is king of the hill. I have one and cannot imagine driving my '12 without it. This gives you an excellent opportunity to get to start know your car and how it works by getting your hands dirty.
