Sponsored by:
Sponsored by:
checked outa 05 vert today
Old 07-25-2013, 10:03 AM
kevinmalec
kevinmalec's Avatar
I have a 2005 V6 and experienced several issues over the years. Before you purchase, be sure to check the following:
1. Thermostat housing leak (if 4.0 V6 model) It's made out of plastic! I had to replace mine recently.
2. Verify all cluster gauges work. The stepper motors are known to go out! My RPM gauge is off by 150-250 RPM. Car should ide around 750 RPM. My thermostat gauge only works if it is 60 degrees or higher. My gas gauge is sometimes off by 1/4 tank, however low fuel sensor light still comes on.
3. Check emergency brake. A few years back, during a cold front, the e-brake froze and doesn't work that great ever since then.
4. Clutch replaced out at 65k miles. Slave cylinder/throw out bearing went bad. I had a 2" dead spot at the top of clutch pedal and I could hardly shift into any gear, I had to jam it!
**Make sure the convertible is fixed, before purchasing! That could be a costly fix!
Good luck!
kevinmalec is offline
Old 07-25-2013, 12:42 PM
zentin
Banned
zentin's Avatar
I would say people are rude these days but everyone posted something polite and helpful besides you, so its all good.
zentin is offline
Old 07-25-2013, 04:28 PM
wcgman
wcgman's Avatar
Dude... are you alright? Verts can be fun, but your posts sound like you might be going off the deep end a little bit. Maybe you're just super excited.
wcgman is offline
Old 07-26-2013, 06:10 AM
dennisafrompa
dennisafrompa's Avatar
Default Cobra rims.....
Not only will your '02 cobra wheels fit but the offset is more favorable. They will come to the edge of the wheel opening.
I have Frpp 17x8 wheel on my Bullitt and the stance is great.
dennisafrompa is offline
StalkerGT
09-25-2015 02:41 PM
TfcCDR
09-14-2015 12:08 PM
Pyrate Dave
09-10-2015 07:30 PM
Mobiusone stang
09-07-2015 08:46 PM
Quick Reply: checked outa 05 vert today
