Hey guys so I have the SR 1.5 lowering springs about a year now and I have notice the inside of my tire is wearing out faster I think on all 4 tires! Any suggestions what can I buy to stop this?
even without lowering you should get an alignment done when going to tires wider than stock.. Thats how I wore out my inner tread about 3x as fast as the rest of the tire.
I had friends help install my Eibach pro-kit lowering springs (1.3" front - 1.5" rear) and had my alignment done, after the springs settled. I did not experience any wear issues with my tires. I would recommend starting with an alignment. The specs will let you know if camber plates/bolts are needed.
You should have an alignment done any time you install anything new on the front suspension; even changing struts will affect alignment. You may find that camber is within spec, but toe is off.
