Sponsored by:
Sponsored by:
Stiff clutch after long drives
Old 09-18-2013, 01:06 PM
parchisi
parchisi's Avatar
Default Stiff clutch after long drives
Hey all, did a forum search but found nothing helpful, so here's the issue.
After a few road trips in the 2011 5.0, I've noticed that after an extended period of driving and not using the clutch (around 1 hr), when I go to use the clutch for the first time (like shifting into neutral on an off ramp) it feels very heavy and slow going both in and out, like it's in molasses. The clutch still functions fine but it's a little unsettling. After pumping the clutch a few times, the feel returns to normal and feels light and springy again. There is no apparent fluid loss and no leaks that I can see.
Can anybody shed any light on this? Also, for the record, the car currently has dot-4 fluid in it. I don't necessarily see this as a "problem," nor is it a safety concern. It could be just an idiosyncrasy of the hydraulic clutch system, but I'm curious nevertheless.
Thanks!
parchisi is offline
Old 09-18-2013, 01:27 PM
Andy13186
Andy13186's Avatar
I get this too sometimes, not sure of the cause. I also would like to know.
sometimes it happens after my car has been parked for a while too
Andy13186 is offline
Old 09-18-2013, 04:04 PM
vixr
vixr's Avatar
after I drive my car something gets stiff, but not the clutch
vixr is offline
Old 09-18-2013, 06:05 PM
2005Redfire6
2005Redfire6's Avatar
Attached Thumbnails Stiff clutch after long drives-ace-ventura-alrighty-then-gmuo4v.jpg
2005Redfire6 is offline
Old 09-18-2013, 11:00 PM
drewsky
drewsky's Avatar
My 06 gt does this every time I'm on the freeway longer than half hour or so. I've actually been wanting to make a thread about the same thing. Feels like a pressure build up
drewsky is offline
Old 09-19-2013, 05:34 PM
Lifter583
Lifter583's Avatar
LMAO!!! I was thinking the same thing!!
Lifter583 is offline
Old 09-20-2013, 10:29 AM
FordService
Official Ford Rep
FordService's Avatar
Hi parchisi,
You should bring it in to your local Ford Dealer and have them take a look at it. The Service Manager is in the best position to let you know if there is work needed, and about coverage you may have for it (warranty, recall, etc.).
Let me know the outcome.
Deysha
FordService is offline
djbigskrilla
09-20-2022 01:04 AM
ak98
09-10-2015 10:33 PM
whatsup62
08-29-2015 01:25 PM
Takeiteasee
08-27-2015 03:59 PM
ccwebb
08-11-2015 06:47 PM
Quick Reply: Stiff clutch after long drives
